Clutch bite
Clutch bite
Postby 5parkyuk » Mon Mar 26, 2012 7:24 am
Ridden about 300 miles on my Sp Now
Have something weird going on with the clutch.
If i give her more than 4 thou she bites like an on of pulsing switch ,anything under its as smooth as silk.
I have bleed it twice.
Any ideas ?
Re: Clutch bite
Postby Sppete » Mon Mar 26, 2012 7:37 am
Have you had it apart yet?
I'd strip it out and check the plates and basket. It may have had a hard time in the past and need a bit of attension. Check the inside of the basket for grooves. It could cause the plates to stick and then suddenly brake free.
It's very easy to get at and you dont even need to drain the oil.
Re: Clutch bite
Postby 5parkyuk » Mon Mar 26, 2012 8:01 am
I Have never stripped a clutch ,no idea where to start to be honest ?
Re: Clutch bite
Postby 5parkyuk » Mon Mar 26, 2012 12:07 pm
NICKED FROM ANOTHER FORUM
Apparently this is a KNOWN fault . :shock: ,here is how you can upgrade.
To change your SP1 clutch plates to SP2 clutch plates, you'll need:
Qty 5, Clutch drive (friction plates), pn 22201-MAT-E00
Qty 1, Disk-A (outer friction plate), pn 22201-MAT-000
Qty 1, Disk-B (inner friction plate), pn 22202-MAT-000
Qty 1, Judder Spring, pn 22402-MAT-000
Qty 1, Judder Spring Seat, pn 22125-MAT-000
Disks A and B are identified by one tab colored green on the outer edge, and have dark speckles on the friction material.
Disk-B is the inner friction plate that has larger I.D. to clear the judder spring.
Disk-A is the outermost friction plate, and has its tabs installed on the shallow slots of the clutch basket.
The 6 steel drive plates are all the same on SP1 and SP2.
On an SP1, to replace friction disks, just order Qty 7, pn 22201-MAT-E00
Re: Clutch bite
Postby Sppete » Mon Mar 26, 2012 3:07 pm
Good find :clap: :thumbup:
Make sure you soak the new clutch plates in new engine oil overnight or it will slip.
I popped mine into ziplock bags because I couldn't find a pot big enough to put them all in at once, you don't have to use half as much oil that way either :P
Re: Clutch bite
Postby VVTR » Sat Apr 21, 2012 10:58 pm
mmmh wonders if the plates are the same on the firestorm as this is also a known fault there too.
mine started doing it after a few runs on the strip at bulldog....
too hard a launch and it goes NERRRRR, grabs, & tries to throw me off the back lol.
tried new storm plates, new bsket etc, same.
one lads even changed out the clutch main bearing thinking it may be that but was the same.
tried taking judder spring out, no difference!
VVTR
Re: Clutch bite
Postby 5parkyuk » Mon Apr 23, 2012 7:36 am
Mines a completes bstard ,anything over 4k rpm and its basically an on off random switch.
Going to try semi synth as im running full at the moment ,just as a desperate measure. :shock:
Re: Clutch bite
Postby steelsey » Sat Jun 08, 2013 6:36 pm
No way, just about to post this question and here it is. I have recently been having a snatchy clutch and thought it was me dumping the clutch too soon but noticed the operation has not been that predictable. One thing I did not address when I stripped my bike back was the clutch. Is the upgrade to the SP2 version the done thing then?
Re: Clutch bite
Postby steelsey » Sat Jun 08, 2013 7:38 pm
5parkyuk wrote:NICKED FROM ANOTHER FORUM
Did you try this? any results?
