Is this wire OEM?
Is this wire OEM?
Postby hanberg » Sun Nov 03, 2013 12:23 pm
So Im going through some wiring, trying to clean it up a bit.
Is this red/white wire with a 30A fuse OEM? Or some leftover from an old install by the previous owner?
Re: Is this wire OEM?
Postby Neil McClure » Sun Nov 03, 2013 5:46 pm
Hi have you got a genuine manual? You will see this is the oem main fuse. Neil
Postby hanberg » Mon Nov 04, 2013 6:00 am
Thanks, actually thought that would be the one next to the starter switch, this looking so DIY... Something to re-wire during the winter
Postby spiv » Wed Nov 06, 2013 6:16 pm
Mine is attached to the flap covering the battery compartment . Standard I think .
