SP1 Discs...
Brakes related queries here...
SP1 Discs...
Postby tonyf » Mon Apr 11, 2011 6:05 pm
All
I'm getting a bit of pulsing through the front brake, so I'm assuming that its a disc. Any recommendations on disc replacemnts from anyone?
Tony
tonyf
Re: SP1 Discs...
Postby Speedytwin » Mon Apr 11, 2011 8:37 pm
If you do need a disci would recomend the honda disc's as there hard to beat. but if it is a slight plusing check the wheel for corrosion between the disc and the wheel as they tend to build up corrosion there under the paint and it can cause some pulsing but may not need discs.
Return to Brakes
