Evening all,
I'm hoping one of you guys can help me out with a problem, or maybe anyone experienced the same problem.
My bike has started to suffer from juddering on the front when braking. The harder the braking, higher the speed the more severe it becomes. Becomes more noticeable when the bike is warm. On Saturday I replaced the brake pads with oem pads (as were previously fitted), pumped out the pistons and cleaned all around them with brake cleaner and a toothbrush. On each caliper I had to block two pistons off to get the others to pump out, cleaned all and pushed back.
Built up, took for a run for 20-30 miles, all seemed ok. Went out on a run on Sunday and the problem re occurred once up to temp.
I'm going to see CheekyKev this week to see if he can help me in any way, just wondered if you lads had any suggestions being SP owners.
A bit about the bike. 2001 SP1, 11.5k miles. Owned since July when it had 7.8k on it. Going through the paperwork it had been stood for 4 years prior to me buying but I have put quite a few trouble free miles on it since. Fluids were changed August last year.
Any info on the same problems or suggestions much appreciated. Thanks, Mark
