Pads and disc
PostPosted: Thu Aug 01, 2013 8:33 pm
by GOOSE_SP2
Im sure this topic has been discussed before but what pads and discs do you guys recommend or run on your SP's?
Re: Pads and disc
PostPosted: Fri Aug 02, 2013 6:35 am
by 5parkyuk
OEM
Re: Pads and disc
PostPosted: Fri Aug 02, 2013 7:03 am
I did the same. OEM.
The Nissens are just as good as anything I've used and the cost the same,so I haven't experimented with this bike.
Whatever you go for, just make sure the front is double H, sintered pad (sorry, granny suck eggs and all that) ;)
Re: Pads and disc
PostPosted: Fri Aug 02, 2013 11:54 am
by sp1Dave
Re: Pads and disc
PostPosted: Sat Aug 03, 2013 8:38 am
by GOOSE_SP2
Ok guys thanks for the feedback, there must be something wrong with my pads then as ive had braided lines put on over winter and the brakes are woeful. Its funny though as I see Pete you mentiond your fork seal leaked and put fluid on the pads, my seals did not appear to leak that far but wondering if they have some residue hindering the stopping power?
Dave how do you get on with that set up as i like the look of those discs?
Re: Pads and disc
PostPosted: Sat Aug 03, 2013 1:17 pm
by nobody
I'm running these but then again I can't leave well enough alone...
Re: Pads and disc
PostPosted: Sat Aug 03, 2013 9:45 pm
Okay, so now I've got a stiffy. Thanks nobody :oops:
Goose. A bit of white spirit will clean any oil off the discs but I would be suspicious of the new lines and a trapped bit of air somewhere first. Also, if the calliper pistons had a lot of dirt around them it could be partially blocking the brake seals if they were just rammed back into the callipers without cleaning.
Re: Pads and disc
PostPosted: Sun Aug 04, 2013 4:11 pm
by GOOSE_SP2
Nobody thats an awesome set up and not out of the realms of possibility.
Pete the calipers have never been rebuilt (maybe part of the problem) and the feel at the lever is bang on its just the fact that the pads dont seem to do anything and its the same as before i put the lines on.
The white spirit, will that leave any residue that will harm the braking or will it just evaporate?
Re: Pads and disc
PostPosted: Tue Aug 13, 2013 8:14 am
Sorry, Late reply :oops:
It'll evaporate :D
Re: Pads and disc
PostPosted: Tue Aug 13, 2013 7:33 pm
by GOOSE_SP2
Cool Pete il try that, i have a set of EBC sintered pads on there way for now. :D
