Getting the exhausts perfect on each side of the bike
Postby pirks » Mon May 01, 2023 9:24 pm
What a complete pain in the bum!
After removing the right silencer (aftermarket) due to removing the swingarm etc to check the bearings, i refitted the silencer and the damn thing isn’t quite level or the same distance away from the rear number plate (used as a reference) as the left one. It was difficult to remove as there was a lot of twisting and pulling involved to remove it due to the gasket in the link pipe to give the perfect seal.
Now have to loosen the silencer from the link pipe as well to twist it back to get it level and maybe a couple of spacers on the rear footrest to bring it out slightly.
Again what a pain in the arse this is turning out to be :roll:
Re: Getting the exhausts perfect on each side of the bike
Postby pirks » Tue May 02, 2023 9:16 pm
Done! but again what a pain in the arse to get them both lined up, i had to loosen all fittings on the exhaust including those on the other side so i could get them to line up.
