WILL SP2 CANS FIT SP1
Postby BIG FRED » Fri Apr 13, 2012 5:51 pm
I have seen a couple of cans on the old flea bay recently for SP2s and wondered if there are many differences or would they fit my SP-Y/1
ITS JUST THAT SOUND
BIG FRED
Re: WILL SP2 CANS FIT SP1
Postby PyRo » Fri Apr 13, 2012 6:35 pm
In a word BIG FRED no. The exhaust ports are oval on the SP2 and round on the SP1.
PyRo
PyRo
Postby turbo_billy » Fri Apr 13, 2012 6:52 pm
I think that any end can is interchangeable from one to the other but the link pipes are different on an SP2 to accomodate the revised swingarm, so as long as you use SP1 link pipes and the bore diameter of the can is the same you should be good to go :thumbup:
Postby BIG FRED » Sat Apr 14, 2012 1:04 pm
Thanks for the advice guys
ITS JUST THAT SOUND
BIG FRED
Postby Sppete » Sun Apr 15, 2012 6:49 pm
turbo_billy wrote:I think that any end can is interchangeable from one to the other but the link pipes are different on an SP2 to accomodate the revised swingarm, so as long as you use SP1 link pipes and the bore diameter of the can is the same you should be good to go :thumbup:
What he said :thumbup:
Postby steelsey » Tue Oct 23, 2012 6:36 pm
So are the header pipes a different diameter than each other? I too have seen some sexy GPR pipes for an SP2 that I would like on my SP1 if they'll fit....
Postby Sppete » Wed Oct 24, 2012 7:34 am
Why don't you ask these Boys?
http://www.gpr-motorcycle-exhausts.co.u ... 0-SP1.html
They might be able to answer all your questions about GPR cans :)
