Does anyone have a photo of their exhaust fitted to the bike with the fairings off? Does the collector box sit parallel to the engine? or does it twist up towards the rear downpipe? I've taken the whole system off to replace the gaskets but whoever had the whole system off last time didn't have the system fitted together properly. The part of the rear pipe that runs into the collector box was only fitted by 6 or 7mm, I'm assuming that the whole system should fit together up to all of the stops? If so, how can I achieve this?
Or is it a case of trial and error?
Thanks
Matt
