Hi Guys
Took my SP1 to Silverstone this weekend around the track. Weather was crap so morning session was wet. Into the third session it rained heavily and in forth the bike seemed to shudder like it was intermittently shutting down and picking up. Thought misfire because of the wet. Striped down and found no damp around any plugs, leads or coils. Went out again and same thing. Let it stand for an hour to have lunch as the sun came out. Went out again and now it started doing it in every gear but noticed when giving it some the engine seemed to race like the clutch was slipping. It's not the clutch as I've just changed it for complete EbC kit and springs and the bolts are still all right. It's just like I'm flicking the clutch lever in and out quickly and keeping the power on. I thought if it was gearbox jumping in and out of gear the box would be noisey. Thought it might be chain slip although front sprocket is worn it still does the job and chain it slightly over tight if anything. Any ideas? It's always has the missing a gear thing the sp1 has but it's only between 2nd and 3rd but read that adjusting the shift rod will sort that out. Although at one point I shifted down backing it into a corner and there was a bit of vibration on the left peg but it was at the same point in the track every time. The problem pretty much screws my day up as could only get 80 out of her down the straights because of it jumping and revving. Any advise or anyone had this before. Never had a problem on the road although I do now but it did get a hammering yesterday. Just to mention I tried going all the way up the box at one point and it wouldn't go into 4th, 5th or 6th but then went down to second and it went all through the gears up and down fine. Thought I'd it was box fault it would either be in or out of gear and not keep jumping in and out by itself.
HELP ME PLEASE
